Look, while the car is being built, they take that car's engine and take the engine all the way to redline and they also spin the engine at different rpm's. This is a pre-break-in process so that when the owner gets his/her car the owner can just drive the car how he/she wants. 4-stroke engines don't break-in the way engines used to...as long as you vary the rpm's, they are fine. As for the gears, they are brand-new gears so they need a couple hundred miles to "settle in" to sort of "learn" how they work in the directions they turn and how they change. This takes about 500-600 miles...during this time you can take the gear to redline, but I wouldn't do a lot of drop-clutching at redline. Haven't you guys ever wondered why no matter what the redline for the engine of the car is, and no matter who the car is from, the manual always says to never go over 4,000rpm?? Also, did you guys know that Porsche has absolutely no break-in period? They just tell you to drive the car the way you want to, and so does the manual...this is the truth for all engines. Another example is with boats and 4-stroke engines (which are essentially car engines). If you get a brand-new boat with a brand-new 4-stroke engine, everyone from the salesman to the manager will just say "drive it how you want, just vary the rpm's".
As for the engine burning oil thing, they say that if you break in your engine real hard, it will burn a little bit of oil for the first few thousand miles, but then it will go away. And they say that if you break in your engine hard, the engine will work harder for you.
Personally, I drove my G35C the way I like to drive (I didn't baby it or anything) but made sure to keep it under 4,000 rpm until about 600 miles. After that, I just drove it how I wanted to. I followed this procedure because I called up Infiniti HQ and spoke with a technician and he told me the true break-in period of the engine is 500-600 miles only for the sake of the gears.
If you broke in your engine improperly, then you would know immediately...you would have engine failure (or the engine will do awful things) and the engine would require engine failure. Otherwise, just like every other new engine, if it is maintained well, it will last for a long, long time.
