Ignition Switch Help Needed
Not sure if this applicable to yours but I found it on another forum;
If you turn the ignition to the accessory position, you should be able to see a tiny hole at the end of the ignition cylinder. Push a piece of stiff wire into the hole. That should release the cylinder and it should slide right out.
